N61JA Rev 2.1 Discrete to uma
engin90
That part has been removed.
The device is energized, has normal behavior, but there is no image.
It also does not come to the external display. The keyboard lights are also not lit.
Do you have any information about the reason?
Hosein Asadolahi
What was the initial problem with this motherboard? Why do you want to disable graphics?
Hosein Asadolahi
at first , you must check all voltage . did you check that ?
if all voltage is present and still haven't image , you must program bios with the correct file .
at last if after resolding vga chip , problem not solved you must think about how to convert this model .
anyway , I guess this model cannot be converted
